주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Volvo가 북미로 수출한 최초의 전륜구동(FWD) 차량
fan is not running
i have a 1995 Volvo 850 series, 2.4 non turbo. My fan is not running either, the relay block has two yellow connetors in the middle, I know these are what control the low and high fan speed. fan test ok for running but when I ground jump the two center relay connectors for the fan speed the fan will not run, acts like there is no power getting to the relay block. thanks, Ken
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
@fathertime24 not sure what you mean by ground jump the two center relay connectors . checking the wiring diagram for your Volvo these do not go to ground and shortening those to ground most likely will not accomplish anything. If anything applying a jumper from B1 to B2 on the relay would bypass the control module.
이미지
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
ken 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 13
전체 시간: 616
