주요 콘텐츠로 건너뛰기
Repair guides and support for your Samsung TV.
20 질문 전체 보기
tv will not keep turned on, restarts all the time
As soon as i turn Samsung Television model PS59D6900D tv on in starts going in to a ever lasting restart circle,in turn it on and in seconds in turns off then turns on by its self
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
@bri29 unplug your set and remove the back. Take some good pictures of all off your boards and post those with your question. In particular your main and power board. that will allow us to see what you see. Use this guide for that
댓글 달기
답변 3개
선택된 해법
@bri29, Ross, I am not a TV repairman, Unplug the TV for a couple hours and then reconnect. Did a bit of searching on your issue and possibly bad on board/manual power switch or faulty board/capacitors. See the video links below to perhaps solve your TV's issue. If your TV happens to be under warranty still return for repair/replacement/refund. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=fbcCVv_a...
https://www.youtube.com/watch?v=H0cG3lzj...
http://www.instructables.com/id/Samsung-...
이 답변이 도움이 되었나요?
점수 2
댓글 달기
See my answer on this here:
There are an estimated 12 million units with this issue, mine included. Class action law suit on it also:
My Samsung smart tv keeps turning on and off
이 답변이 도움이 되었나요?
점수 2
댓글 달기
I had that problem which was fixed by disabling "Digital text" in the menu options.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
problem is that it dont stay on long to get to menu,just got time to pull menu up then turns off
Hi, I only had a problem on two channels so picked a working channel before accessing the menu. If you have a working channel, try that one to get into the menu. Hope that helps.
댓글 달기
답변을 추가하세요
ross 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 3,111
