SP 1020 Skytex tablet
why is my battery not recharging? All the power has drained out.
좋은 질문입니까?
좋은 질문입니까?
Hi,
Does the tablet work OK when the charger is connected and switched on? Does the tablet indicate that the battery is being charged?
If it works with the charger connected:
then it may be that the battery is failing and needs to be replaced.
Here is a link to the ifixit battery repair guide for your tablet.
Here is a link to just one supplier of a replacement battery. It is not a recommendation to use them, it is shown to give an idea of the price. There are others online that may suit you better. Just search for Skytex SKYPAD SP1020 battery for results
If it doesn't work with the charger connected or show that it is charging:
then problem could either be a faulty charger, a faulty or loose power socket in the tablet or a fault in the systemboard.
Have you tried a different compatible charger?
If you don't have another compatible charger or access to one do you have a DMM (Digital Multimeter) or access to one?
If so you can use the DMM's Voltmeter function to prove that your charger is working correctly. Just place the Voltmeter test leads across the charger plug's inner and outer connectors to measure the output from the charger when it is connected to the wall outlet and switched on. It should measure 5V DC.
If the charger is faulty here is a link to just one supplier of a replacement. It is not a recommendation to use them, it is shown to give an idea of the price. There are others online that may suit you better. Just search for Skytex SKYPAD SP1020 charger for results
If the charger is OK then you need to open the tablet to further diagnose the problem.
Hopefully this is of some help.
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 8
지난 30일: 17
전체 시간: 558
댓글 1개
More details please
Cameron 의
