주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
iPhone 5S water damaged
I put my iPhone 5S in the washing machine and dried it in the rice box for 3 days. After 3 days, when the phone is plugged in, the screen turn on and show the Apple's logo for 0.5-1 sec and turn black. The screen just show a black image but not totally turn off. iTunes can't recognize my phone.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Unfortunately, the worst thing you could possibly do was to let water fester and corrode your phone for a few days while it was sitting in rice. The water is in the phone, on the logic board and under the shields, even under the IC's. The rice is nowhere near where the water is...it cannot help your phone.
When the water is allowed to evaporate, it leaves deposits of minerals that can cause short circuits or corrosion. Heating or powering the phone accelerates the process. The water needs to be displaced, not heated and evaporated.
Sorry about that, now on to helping you.
  • Open your phone and remove the logic board (follow this guide)
  • Inspect the logic board, especially around the connectors and look for corrosion.
  • Inspect both sides of the board. Unfortunately, 80% of the board is covered in shields. That's usually where the damage is occurring.
  • Put your board in a container with >90% isopropyl alcohol and let it sit for a while.
  • Use a soft brush, like a toothbrush and lightly brush away any corrosion you see.
  • Rinse in alcohol and repeat.
  • Let it air dry for a day.
  • Re-assemble and hope for the best.
  • Use a tool like 3uTools to flash the firmware as it may be corrupted.
  • You should also consider getting a new battery
A professional repair shop that does water damage repair may be able to recover your phone or the data because they have access to pro-level ultrasonic baths and specialized cleaners as well as the skills to troubleshoot your board.
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
take a look here
Electronics Water Damage
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
toanvu 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 8
전체 시간: 4,547
