주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2016년 6월 출시, 유럽 모델 번호 A3003 및 중국과 북미 모델 번호 A3000(https://forums.oneplus.net/threads/oneplus-3-regions-model-numbers.452381/ 참고)으로 식별됨
LCD + Frame Replacement
Third parties offer the LCD screen replacement with or without FRame assembly.
My question is , will the LCD + Frame assemblies include the two capacitive buttons? I believe it should because those two buttons are in between the two.
hence if i buy the Frame + LCD assembly then i would not need any heat to make the screen replacemnt.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
Here is the link of the repair guide OnePlus 3 스크린 및 디지타이저 어셈블리 교체
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
This doesn't answer my question...if I buy the LCD + Frame from a third party, do I have to take it apart in order for me to.install the two capacitive buttons?
의 공유
yes, you have to salvage the button from the old screen.
의 공유
댓글 달기
If you buy an LCD with the frame it should have the hardware buttons preinstalled as the hardware buttons are located between the LCD and the frame, all you have to do is connect the display, fingerprint and hardware buttons flex cables when reassembling the device. Remember the OnePlus 3's display should be an AMOLED panel and not LCD, make sure you pay attention to this when buying if you want the display to have the same quality as the original. :)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Like Joseph said, make sure its Amoled not LCD. I accidentally bought a LCD replacement display. While functionally it works, it does not look NEARLY as good. It was quite a bit cheaper tho, around $50
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
carlos 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 18
전체 시간: 1,715
