주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG X Power는 2016년 8월에 출시된 4G LTE 스마트폰입니다. 이 모델은 16GB 메모리를 탑재하고 있으며 안드로이드 운영 체제(OS)로 구동됩니다.
My touchscreen not working
I had my phone in my pants pocket and it had a case on it and it rained a little bit got my pocket wet a tiny bit and after I went on lunch for work my touchscreen wont respond I reset my phone but I cant click next to set it up
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 1개
try taking the phone completely apart, and checking all the connections and letting it fully dry out if it isn't.
make sure the touch screen is receiving power from the charging port. Let us know if this helps or if you find something, good luck!
You have to do an advanced hardware reset by first removing the battery for 30 minutes. Set a timer. After 30 mins, replace the battery and hold the volume down button for another 15 minutes. Set a timer. After 15 minutes, release the volume down and press volume up button rapidly 3 times and then immediately remove the battery again, this time, also remove the sim card. Wait about 30 seconds, and replace battery and sim.
When you power the phone back on, you should get a prompt asking you which hardware component to update., Select "screen sensor" by scrolling through the options with volume down and select it by pressing volume up. The phone will now reset the "screen sensor" hardware data and download the newest hardware update for your phone.
Screen should now be fully functional.
이 답변이 도움이 되었나요?
점수 0
댓글 4개:
Unfortunately i cant take the battery when i try to it bends the nattery
의 공유
I have this same phone. You can't take the battery out.
의 공유
never heard of an "advanced hardware reset" ...
will try it now and report the result
의 공유
Well, it's like i thought, not working
의 공유
댓글 달기
답변을 추가하세요
Jango DarkWind 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 12
전체 시간: 6,055
