Right ear quit working
Out of nowhere the right here stopped working so i wiggled the wire a little it gave a little sound for a couple minutes. Then just stopped completely. I couldn't find my receipt so the warranty is out of thee question. So i decided id take the thing apart and try to fix it myself. I got inside and im not sure what to do now. There are no videos on how to do it so i need some help. The wires seem to be soldered in place but im not sure if they need to be connected to something else. Here is what the wires look like now: http://imgur.com/a/AVEv1
좋은 질문입니까?
댓글 12개
how did you take it apart? my window curtain decided to knock the headset off the shelf and the right ear sounds really tinny and no bass comes from it now. i think the speaker is loose and need to get in there.
Patli 의 공유
@patli Take a look at this thread: How do I open the the control panel of the headset
Rachel Acosta 의 공유
It isn't solved. One ear, the one with the mic, has an extra wire in it for the mic. The right ear doesn't contain a mic so it only has one wire. It's supposed to have one wire.
Flippy Flip 의 공유
i've just excperienced this, no sound in the right ear, no matter how i move the cord theres no sound, pls help
Etz 의 공유
Before you guys do anything, check the balance. Go into playback settings then click on your headset and select properties. Go to Levels and then Balance, and make sure both speakers are getting input. For some reason, my right was on 0 and my left was normal, so only left played sound. If that doesnt work, try using a different usb port and then try unplugging and replugging in your 3.5mm jack into the usb dongle. If NONE of those work, its the headset...
Mohammed elk 의 공유
댓글 7개 더보기
