주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Toro Company에서 제조한 보행형 잔디깎기에 대한 수리 정보 및 지원.
Why is the engine over revving?
With the engine running the governor doesn't seem to be controlling the engine rpm's and over-speeding. Throttle control cable doesn't seem to be controlling the engine
speed whatsoever.
Thanks, Tom of Indy.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
What model is your mower? Is it ride on?
tjcox6841 anything related to engine adjustments etc. will be in the Tecumseh manual. Let us know if you can find any model number or other indicator on the engine.
My cross reference shows that your mower should have a Tecumseh TVS840-8014B
댓글 달기
답변 2개
선택된 해법
tjcox6841, Tom, You did not state your engine or model #, so I will post some what generic answer. Sounds like the governor linkage may be stuck, broken linkage/spring. Look for dirt/debri around the governor linkage and wash/brush/blow any debri from linkage and ensure linkage mechanism is intact and hooked up and throttle cable is still hooked up and not broken/seized on. Links below may be of some assistance. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=shgawgDT...
http://www.hobbytalk.com/bbs1/110-small-...
https://www.youtube.com/watch?v=EVIZtyw3...
https://www.google.ca/search?q=tecumseh+...
이 답변이 도움이 되었나요?
점수 6
댓글 9개:
Toro Model #26551 tecumseh two cycle engine.
Governor linkage is free ,however I believe the adjustment may have been changed.
@pccheese when you vote an answer down, it polite to state why you did it. Why did you vote this down?
@mayer Oh, pure accident. I ment to vote it up.
@mayer , @pccheese Thanks, I was scratching my head on this!
댓글 4개 더보기
댓글 달기
tjcox6841 here is the description from the manual for the TVS series engine. Let us know if this looks like what your engine uses. If so, I can probably provide you with the rest of the manual, but cannot post it due to size limitation. Post some images of your engine, your carb and your governor linkage etc. Use this guide to do so. This will allow us to see what you see.
이미지
이미지
이미지
이미지
이미지
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
tjcox6841 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 37
전체 시간: 53,880
