주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1995년에 출시된 1인용 3D 32비트 게임기인 Nintendo Virtual Boy의 수리 안내서, 분해도 및 문제해결 정보입니다.
Left eye keeps glitching
The only problem I have with my virtual boy is that the left eye keeps glitching out, the right doesn't glitch at all, it's only the left one. Please help!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
that was so ninedys
의 공유
댓글 달기
답변 3개
가장 유용한 답변
Unfortunately, Nintendo cheaped out when it came to the VB. The ribbon cables that connect the motherboard to the display LED board isn't soldered; they're GLUED. So even with old new stock VBs, the glue will degrade and relax the pressure, losing connectivity.
It is possible, though not for the faint of heart, to open the VB, remove the glue, scrape away a bit of the ribbon cable to reveal the metal traces, and solder those traces to the LED board. This is a permanent fix, too - unless you screwed something up, you'll never have to worry about the display glitching again...well, for connectivity issues.
이 답변이 도움이 되었나요?
점수 4
댓글 1개:
I have actually undertaken to create a brand-new replacement cable for the Virtual Boy, which I call the VirtualCable. It still requires soldering in place, but has helpful features like castellated pins for the LED board side and 3M tape to adhere and stabilize the cable.
Price is $11/pair before June 1st, $15 a pair afterward. On June 1st I'll shoot the order in with my fab house to start production. If you want to join and get a pair (or ten!), shoot me an private message on PlanetVB.com.
Link to the project here:
https://www.planetvb.com/modules/newbb/v...
의 공유
댓글 달기
My right eye screen is glitching. The screen has a vertical offset, many distorted pixels, it doesn’t happen on all screens during the startup of a game, I did try out several games). It has only been doing this very recently (2019), so I’m in doubt if it’s really the degradation of the flat cable connection (through glue). In it’s 23 year lifespan, that’s quite sudden/seems late?
A student of mine inserted a cartridge with the cap still on. Luckily I was able to remove the black cap from the slot, but I wonder if it could be one or more of the pins that plug into the cartridge are not fully connecting that will cause the glitch?
이미지
이미지
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I seem to be having a very similar issue, happened suddenly in 2022. I suspect a cartridge connection issue but can't confirm. I think I'll try compressed air before I go opening it up and checking out the glue situation.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Retro Rider 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 8
지난 30일: 53
전체 시간: 4,421
