주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
JBL Charge 3는 독특한 직물 스피커 커버와 고무 소재의 포인트로 알아볼 수 있습니다. 2016년에 출시되었으며 완전 방수 디자인, 20시간 재생 시간 및 블루투스 연결성을 특징으로 합니다.
Why is there Static Noise?
Hey everyone, a couple weeks ago I bought a JBL Charge 3. I instantly loved the speaker. But recently I noticed it had some static noise, like a radio that is untuned. Everytime I turn them on, not even with a device conected, I get the noise, no matter the volume or anything really. I havent put them on water or sand or dust, nothing. What could be causing this? Is there a solution to it? Are the speakers defective?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 10
댓글 달기
답변 8개
가장 유용한 답변
If your JBL speaker produces distorted sound, see the JBL Charge 3 Sounds Distorted problem page for possible problems and solutions.
I think the speakers are being overpowered. I took my charge 3 apart and just watched the speaker as it was being used and saw no blown parts and no loose seals, but when I touched the positive lead wire that connects the red wire to the underside of the cone part of the speaker the static instantly cleared up and came back soon after I remove my finger. Did this multiple times and got the exact same result every time. So either the power needs to ramp down, the wire needs to be coated, or the speakers need to be grounded.
이 답변이 도움이 되었나요?
점수 6
댓글 1개:
Thanks bro! i have my jbl plugged in my pc and i have it charged all day. when i remove the micro usb the static disappears
의
댓글 달기
I had the same problem with my JBL Charge 3 I contacted customer service the device was still under warranty so they sent me a shipping label and a way to return the unit for a replacement. I have the new unit now, it worked fine for a couple weeks with no problems, now I have the same staticy noise. I've contacted customer service again about the problem and the only solution that they can come up with is to send me another replacement speaker. Hope this helps. Good luck.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
Reboot your phone then try agian,
의
I just bought the JBL BOOMBOX3 at Costco and It’s statics the whole time just as the above person said sounding like a radio that’s untuned or like it wants to cut out with bad reception. My small JBL that I have JBL essential sounds way better and never has that same static sound. I also have a small clip speaker that I take to the lake on my paddleboard and it never statics either even in the most remote areas so something is wrong with this new boombox which I’m really bummed about because it’s a $500 speaker at Costco!!!
Now that I read the above comment, I will return it because it’s not getting better. I’ve been listening to it all day as I pack for moving for a week now and it just continues to static. My little speaker sounds beautiful compared to my big boombox I hope they fix this problem because I really love the style and the sound
의
댓글 달기
There is a YouTube video of a guy fixing his Charge 3 by soldering the braided speaker wire (that runs in the cone) to the tab that the power wire go to. Should probably do this to both braided wires on both speakers.
https://www.youtube.com/watch?v=uv3LVFUu...
Cheers, TQ
이 답변이 도움이 되었나요?
점수 3
댓글 달기
Some people suggest that the glue that holds the golden wires to the cones starts to dry/crack, which causes it to rattle. You can use silicone or glue to hold the glue that is on there down, and the rattling should stop. If this makes you nervous, adjusting the golden wires by moving them around can also seem to fix the issue, which is a lot easier.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
its because the speakers on the inside have weaker magnetic pull
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Very likely that one (or both) of the speakers are blown. I had a similar problem with the left-hand speaker. Tried soldering the braided wires that go into the cone. Soldered them to the back of the tabs that connect to the power leads. Wasted a bunch of time fiddling with the existing speakers. Finally broke down and ordered some replacement speakers from China. Done!!
Good luck!!!
Cheers, TQ
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
The speakers are not blown. This is a brand new unit and other people are complaining about it doing the same thing static out of the box 1st. I thought it was my Spotify and now I know it’s the speaker because my small JBL sounds beautiful and it’s old and I’ve blasted it for years now.
의
댓글 달기
Had the same noise problem. Based on earlier answers, I opened up the unit but found no problem with the speaker, nor its wiring. Noticed the battery quite weak. After charging, the noise disappeared.
Conclusion: the battery was not properly charged.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
It sounds like your JBL Charge 3 might be experiencing interference or an internal issue. Here are a few things to try:
  1. Reset the Speaker: Hold down the power button and volume up button simultaneously for about 10 seconds until the JBL logo blinks.
  2. Update Firmware: Check if there’s a firmware update available via the JBL Connect app.
  3. Check for Interference: Ensure there are no nearby devices causing interference.
If these steps don’t resolve the issue, the speaker might be defective. Consider contacting JBL support for further assistance or a possible replacement.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ignacio Ramirez 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 21
지난 30일: 67
전체 시간: 63,172
