주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony에서 제조한 MDR-ZX100 ZX 시리즈 스테레오 헤드폰입니다.
Both the speakers are not working
Both the speakers are not working and I have checked the whole wire and it is working for another speaker and I have connected the speakers with another wire it not working...hence the problem is with my speakers. Please help
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
nitheesh k unlikely that both speakers have failed. Check the 3.5mm plug. Check it and replace it as necessary, follow this guide Skullcandy SCS-SCBP SKULLCRUSHERS 3.5mm 플러그 수리 to do so. Different model headphone but identical procedure. you can also check the wiring to the drivers (speakers) by using this guide Sony MDR-ZX100 수리 방법 and measure continuity with a multimeter from the connector to the drivers.
Skullcandy SCS-SCBP SKULLCRUSHERS 이미지
안내서
난이도:
조정
45 minutes - 1 hour
Sony MDR-ZX100 이미지
안내서
난이도:
조정
15 - 30 minutes
이 답변이 도움이 되었나요?
점수 1
댓글 달기
The problem is most likely with your speakers, but it is unusual that both speakers fail together. Are these speakers connected to a computer? Such have a power supply inside one of them and if that fails the speakers do not work. As most of these have an external wall-plug supply, check this (measure voltage at the output plug). If there is no voltage just replace the "wall-plug" supply with one of the same voltage and Ampere rating.
If your problem is with regular speakers that you connect to am amplifier I have no idea what may be wrong with both of them.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
nitheesh k 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 15
지난 30일: 24
전체 시간: 387
