주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
iPhone stuck in restoring
Tried to update phone's OS from 8.2.3(or something) to 10.2.3 only to have it stuck with the apple logo and the progress bar. As it reaches about 70 percent of the bar, it stops moving forward and eventually restarts.
I put it into DFU mode, tried updating with another computer and eventually it worked. Unfortunately, I'm now trying to revert back to the backup I had saved of the prior OS only to be stuck with the same problem with the progress bar and the apple logo as it reboots endlessly as the bar reaches about 70% and stops.
Am glad to provide any other helpful info.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
Are you trying to restore the whole IOS system or just your files?
And you didn't by any chance happen to save your SSH blob? Unless you have, there is no way to downgrade your phone as Apple has stopped signing older versions of IOS.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
I certainly wish I could restore the whole OS. I thought I could do so if it was from a backup. The files aren't as much of a matter, but still I'm annoyed that the phone gets stuck in a reboot loop.
Unfortunately not. Wasn't even aware of such things before updating. It turned out to be such a nuisance I felt like smashing the bloody phone, especially since it already had some problems and now they've been worsened by the update. Ah, well.
I guess you know for next time!
(If the answer helped you, id appreciate if you could mark it as there chosen answer).
댓글 달기
Not 100% sure this will work for you as it did me, but I heated up the phone a bit...about 80c to the back where it was very warm to touch and it completed with no errors. I eventually removed and reballed the NAND and issue went away all together.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Huh. Sounds like a rather unorthodox solution, but I might give it a try. I do wonder, though, how does one come up with these ideas for fixing a problem like this?
댓글 달기
답변을 추가하세요
Smeargle 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 174
