How can I unlock my iPod
My little sister was play with it and lock it. I forgot my combination and can't unlock it.
좋은 질문입니까?
좋은 질문입니까?
Here is a link to Apples procedure for setting and removing the lock. Please note you will lose all your data. Good luck.
이 답변이 도움이 되었나요?
rj713 is of course absolutely right. There is a also another way to reset it without losing the data from your ipod :
first plug in the ipod, go to my computer, click on the ipod drive. Go to tools > folder options then click view. Click show hidden files,
Go to ipod_control, then go to device. There should be a file named "_locked" delete that. Now unplug the ipod and you should be ready to go
Good luck
이 답변이 도움이 되었나요?
didn't work so don't konw
it did not work
This Helped Alot Thank You
It worked for me thank you a lot.
Go to Ipod folder in computer make sure hidden files are displayed
go to
-ipod_control
--Device
---_locked
don't delete it, just change it to un_locked
worked for me many times, just don't know how to full remove code or change it without restoring ipod
이 답변이 도움이 되었나요?
Telling her how to show the hidden files would greatly improve your answer.
This actually worked for me! In explorer go "View > Hidden Items" and uncheck it. Then go to the folder "IPod_Control" and do as described above.
지난 24시간: 2
지난 7일: 8
지난 30일: 21
전체 시간: 15,224
댓글 2개
ive down loaded some music and turning it back on its showing the padlock feature and i cant unlock it ...how do i unlock it
bernard 의
It may also be called _volumelocked
Simon Pugh 의
