주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
lost a small connector, phone still works
My phone stopped charging so I replaced the whole charging port, but this small connector right above the loud speaker fell off its wire. The thing is my phone works like normal. I can charge it, wifi works, 4g works, speaker works.
I dont understand, what does that connector do? I tried adding a photo
https://gyazo.com/db200d81f3e0a517ea5cac...
edit: The connector im talking about has a red circle around it on the picture, the wire it used to sit on has a green circle
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Thanks, I tried called two people and had no problem with the signal, I guess its no a big problem then.
How possible network connector is open and phone still get network
댓글 달기
답변 3개
가장 유용한 답변
This is the main cellular antenna, right now your phone is on secondary antenna so it still appears to work, but expect significant 4G speed reduction and increased battery drain.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
REF: iPhone 5s Lightning Connector Replacement
Look at Step 23. Are you referring to the antenna connector? Is it a round connector attached to a 1 inch long cable that pushes on top of its mating connector on the circuit board? I believe this is your primary/main antenna for cellular reception. Given that you have cellular reception, my guess the consequence for breaking this connector will be you won't have cellular reception is weaker signal areas where you used to have reception.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hey!
Shortly: This is the cell-antenna and you need to connect it on the board at this little round connector.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
soeharebrentpådvd 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 62
