주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
서드파티 및 Microsoft Xbox, Xbox 360, Xbox One, 그리고 Series X|S 공식 컨트롤러에 대한 수리 정보 및 분해 안내서입니다.
Why is my Xbox One Controller not syncing?
So I recently put my Xbox One for sale because I am planning on buying the Xbox One S. Instead of using my console to play games and risk breaking it before I sell it I am using my PC to play games with my Xbox controller. Now last week I had my controller next to my monitor and next to that was my bowl of cereal. I went to go use the bathroom and when I connected my controller to my PC via USB and crushed some Far Cry Primal. After about 30 minutes my controller started to get sticky, I looked around the analog sticks to find milk all along with the sticks and some of the buttons. As it turns out one of my siblings hit my bowl of cereal and some of the milk went on my controller. I didn't really think much of it other than it making my buttons sticky so I used a Q-tip, some alcohol and cleaned it, I thought it was fine. Later that night I decided to see what was up with my Xbox and all that jazz. Every time I connect my controller to my PC I have to sync it back to my Xbox, so that what I did. Expect this time it wouldn't sync, I tried for hours, did the troubleshoot, watching videos, it just was not syncing. Soon after that my controller started to "malfunction". I don't quite know how to explain it but whenever I held onto the Xbox controller button it did not flash white slowly, instead, it would only flash or turn white when my actual finger was on the button. Once in a while, it would do the regular "waiting for you to press the sync button" flash. When that would happen I of course pressed the sync button, the button itself would not even make the light flash rapidly unless I pressed the sync button a second time. Even then it still would not sync to the console. I finally gave up and decided to void my warranty and open the controller when I did I found that some of the milk got on the circuits I thought to myself I FOUND THE SOLUTION!!!! So I cleaned it with the rubbing alcohol and made the circuits look all nice and shiny. I put the controller back together and it still wasn't syncing. The controller works fine if you plug it into the console via USB I even tried updating the firmware, but it still does not work. The thing is I’m selling it so I don't know if someone would like to buy a "not anymore wireless Xbox one controller." I’m hoping the smart people here can help me fix it, asap would be greatly appreciated too!!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 4개
My Xbox did the same thing, all that happened was that we turned the Xbox off and back on 3 times and did the same with the controller while it was connected. If that doesn’t work then keep turning it on and off and checking it between times, if that doesn’t work... I’m sorry
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Try unplugging the power brick, wait a few seconds then plug it back in. It worked for me.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I’ve tried and you have to unplug both cords on the back of the Xbox, the cord going to the tv and the cord going to the power brick (do not unplug the cord connected to the brick)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
If your Xbox One Wireless Controller is not syncing or connecting to your Xbox console, see the Xbox One Wireless Controller Won’t Connect to Console problem page for possible causes and solutions.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ohenmaa OfosuMensah 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 20
전체 시간: 10,722
