주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung에서 제조한 Samsung Galaxy Note 5는 (Note5로 불림) 스타일러스를 탑재한 패블릿 스타일 휴대폰입니다, 2015년 8월 출시.
*67 in text message?
I just happened to look at the contact number I was getting ready to text and saw that there was a *67 in front of the phone number. How did that happen? I didn't put it there. Does that mean the other person wasn't receiving my text messages?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
Ok. First start with turning it off and on again. Then try a force restart
To force restart your device, press and hold the Volume down key and Power/Lock key on the device for 10–20 seconds. This performs a simulated battery disconnect
If that doesn't take, then you'll likely have to restore, which you'll want to backup your data
From a Home screen, tap Apps . These instructions apply to Standard mode only.
Tap Settings.
From the Personal section, tap Backup and reset.
Tap Back up my data to turn on or off .
Tap Backup account.
Tap the appropriate account.
Tap Automatic restore to turn on or off.
이 답변이 도움이 되었나요?
점수 1
댓글 7개:
I went to contacts and made the number the default number and the *67 went away. But HOW did it get there in the first place? So when I sent text msgs to this person, does this mean they didn't get them?
의 공유
Probably not. You'll have to resend. The contacts thing was good to know. I'll keep that in mind
의 공유
If anyone cares (*67) is Caller ID blocking. I have a feeling someone at some point got a hold of the phone and wanted to try to send texts without wanting the person on the other end knowing where it came from.
의 공유
@avanteguarde cool to know! Thanks, bruv
의 공유
My problem is a certain number automatically gets a *67 added Everytime I try to text it. I don't understand this.
의 공유
댓글 2개 더보기
댓글 달기
답변을 추가하세요
Michelle Haith 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 22
전체 시간: 2,309
