주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2011년에 출시된 ThinkPad입니다. 이 T420 버전은 T420s보다 두껍고 통합 USB 3.0이 없습니다. T420i는 동일한 섀시를 사용하므로 대부분의 T420 수리 안내서를 상호 교체하여 사용할 수 있습니다.
Sim card slot problem
My lenovo thinkpad t420 has a sim card slot under the battery but it does work
is it whether the slot is fake or there is other problems with it
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
You do not need lenovo access communications software to run the modem card. Simply use the internet settings in windows, and double check the sim card is activated and inserted the correct way.
의 공유
댓글 달기
답변 1개
선택된 해법
Hi!
Many business class laptops have SIM slots under the battery, but they only work if there's a special PCIe WWAN to connect to the carrier installed. You can check if yours has that component if you follow thisvideo and open your laptop up.
Thisis how the part looks like, if you'd like to get yourself one.
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
The SIM card slot on the T420 is in the battery bay, but the WWAN card is located by the bottom RAM module. That's the WiFi card.
T420 RAM
의 공유
I have a t480 and i inserted a active simcard from my tablet but still no mobile internet access. Is there an extra step or software i need to download to read the simcard?
의 공유
@Raj Garcha Is it have a WWAN card? Most people pass on the option unless it's a major corporate purchase with a bulk data plan. I've never seen anyone take it personally.
It's usually on the spec sheet so if I'm not sure, then I can quickly see. They usually come with the systems when you buy them used, but some companies remove it.
의 공유
댓글 달기
답변을 추가하세요
pnshuti60 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 34
전체 시간: 11,392
