주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DJ 컨트롤러를 위한 수리 및 분해 안내서 모음입니다.
Numark Mixdeck Express keep shutting off and on
My Newmark Mixdeck Express keeps shutting on and off
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
Why does my keep cutting please
의
i use gotv adaptor to power my numark mixdeck quad and it keep oning and off what can i do
의
댓글 달기
답변 2개
가장 유용한 답변
Mark Zellous appears to be a protection circuitry that prevents your controller from powering up. You will have to open it up and take a look at the power supply. Check the MOSFETS and capacitors for obvious damage. There is not a whole lot of information about your device out there so we will have to go by trial and error to help you with that.
Depending on the age of the controller and where you purchased it from, you do need to check for any warranty etc.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
의
@sunshinesai8393 tell us more about what this adapter is. What voltages does it deliver? What have you checked?
의
댓글 달기
My numark mixdeck express cuts off why I'm djing
Update (04/03/2020)
I be playing my numark mixdeck express an its cuts off cut back on then it stop want do nothing
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Have you checked to make sure your USB port isn't loose and possibly causing the short. I repair these type of units and I see the USB ports go bad on these or sometimes there might be a bad cap or something short circuiting in the power line.
CoCo The Geek
의
의
댓글 달기
답변을 추가하세요
Mark Zellous 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 30
전체 시간: 1,642
