Mike, the charge port is readily available and an easy fix. Watch the youtube video on how to do it and get the replacement charge port here in the States.
Henkjan, I found some replacement speakers from China that were the right dimensions for the Charge 3. Had to knock off the little guide post off the JBL frame that went through the speaker frame, but that is no biggie. I also put some flat washers (two in each corner) between the speaker and the JBL frame. Still had enough compression on the seal to keep it water resistant. Good luck.
Cheers,
TQ
Here are two of the ones I bought that will fit:
https://www.ebay.com/itm/162694336905
https://www.ebay.com/itm/254053310184
As mentioned, the little "posts" on the JBL frame must be removed, or a hole would have to be drilled in the speaker frames to accomodate the posts.
Cheers,
TQ
6 댓글
I want to know the same thing. Cheers, TQ
Trevor Quentin 의
Yeah mine got a hole in the left speaker but no where to find
Cheers,
HJ
Henkjan 의
Looking too. The charge port completely fell off. I can no longer charge my JBL3 :(
Mike Bauck 의
You can replace the charge port, get the part on Amazon as well as the battery. Speakers you can find on Ebay.
Ruben Marin 의
Hello, you can easily get speakers for JBL Charge 3 on the following website.
Original spare parts : https://ecommerce.mysav.eu/en/jbl/147-sp...
Raymond L. 의
1에 댓글 더 나타내기
