주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo Switch Joy-Con 컨트롤러의 수리 안내서와 정보.
Replaced joy-con shell; bungled joystick?
I did a shell replacement on my whole Switch, including the body and both joy-cons. Everything went great except for the right joy-con: I must have screwed up the joystick because now it’s permanently sending “joystick right” anytime it’s connected to my unit. The joystick itself looks just fine, it doesn’t look bent. The only thing I can think of is maybe I screwed up the ribbon cable when I plugged it back into the joy-con circuit board.
Has this happened to anybody else? If so, is there a fix? If not, is there a place I can buy a new joystick assembly for the right joy-con?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 1개
가장 유용한 답변
I have a similar issue - try lifting the rubber flap that covers the Joystick guts (just under the stick). Then blast some compressed air into here and move stick blast, move stick, blast. See if that helps. Then run the analogue stick configuration from settings.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
How did you get the rubber cap back on? It won't fit in for me.
의 공유
You list it back with two pins it will flap and stay back if done right. A little fiddly but if not you hold while someone else sprays
의 공유
댓글 달기
답변을 추가하세요
Ben Kreeger 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 21
지난 30일: 40
전체 시간: 2,947
