주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS ZenPad 3S 10은 ASUS가 2015년 10월에 출시한 ZenPad 라인의 9.7형 태블릿입니다. 모델명: P027.
Is it possible to replace the touch screen only?
I have a cracked touch screen on my Asus Zenpad 3S 10 Z500M but the display is not affected. I only see the whole assembly for sale online so I'm presuming this tablet is one that requires the whole assembly (expensive) to be replaced. Is it possible to replace the screen alone?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 4개
Hi
Asus parts (click on LCD panel link in middle of page in link) doesn't list the digitizer as a separate part so I think that your assumption that it requires a whole assembly is probably correct.
Be warned that the glass (digitizer) can be purchased separately on e-bay. However, it seems impossible to remove the glass from the LCD panel. This is likely why Asus does not list the part(s) separately, and buying the glass separately may be worthless.
I have a ASUS ZenPad model P027, but I measured it across, and it measures less than 9.5 inches. The thing that bothers me is that the spec says 9.7 inches. Is that correct?
Cracked screen touch screen not working
댓글 달기
답변 3개
가장 유용한 답변
yes it is possible to do the glass only but it is not a simple job, i highly advise purchasing complete as glass only requires specific tools that you may or may not have access to and the chance of breaking/burning the lcd is very high
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
I found it is better to just buy the screen/digitizer assembly. It is not too terribly expensive and available through eBay.
댓글 달기
A lot of repair options are POSSIBLE, but some turn out to be not PRACTICAL.
Most experienced electronics repair shops would still purchase the more expensive full assembly: cover glass, digitizer and lcd in one. Separating the old laminated parts is too time consuming and risky for a single job. Glass-only repairs only make sense when refurbishing thousands of screens at a time, so that you can afford to by the expensive tools required to do it right.
The factory vendor posting on eBay or AliExpress does not care if their glass-only part is a practical option for their customer. They just want to sell as much glass as possible.
Think of the windshield on a car. This is made of multiple layers of glass and plastic all glued together. If you cracked the top layer of the windshield only, you would never consider stripping it down to preserve the bottom layer by replacing only the top. Anyone would choose to simply buy a factory made assembly of the whole windshield.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Yes it is possible. I removed mine originally before I realized I needed both. Still got that glass. But its for a ZenFone 5.
I also need to replace my screen/digitizer for my ZenPad s3 (10) z500m. But the cost is ridiculously high! Unless someone knows a cheaper source. Thanks
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
Hi @groggzilla ,
Just so we know how high to set the bar.
Is this too high?
Cheers.
is thre a little cheaper sceen plss help
and is there a home button with fingerprint replacement too?
Did you manage to separate the glass from the LCD? I was stupid buying the digitizer only and I cannot find someone who is capable of doing it :(
댓글 달기
답변을 추가하세요
David Abel 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 17
지난 30일: 24
전체 시간: 6,723
