주요 콘텐츠로 건너뛰기
The Dell Inspiron 15R 5520 laptop features a 14.88" screen, brushed aluminum finish and features a i5 core processor .
12 질문 전체 보기
Broken Headphone jack. Is it fixable>
Long story short, I broke my headphone jack on my Dell Inspiron 5520 a while ago and today was the last straw. Is it possible to replace the entire jack without doing and soldering? Here's the part and I dont know if it just sits in place or if it requires soldering.
https://www.aliexpress.com/item/Audio-Ja...
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi!
The broken headphone jack needs to de-soldered from the motherboard and replaced with the new one, that needs to be soldered back on. At the same time you need to use a special soldering iron (or a very good one) to melt the solder. Also, laptop boards are very complex and usually multi-layered, therefore using a soldering iron could break some traces or parts on the other side with no visible damage, aggravating the problem. A more elegant solution would be replacing the entire board or even taking it to a computer repair shop.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Desmond Waters 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 9
전체 시간: 349
