주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Chromo Noria는 Android 4.4 KitKat이 탑재된 7인치 Android 태블릿입니다. 블랙, 블루, 핑크, 화이트 색상으로 출시되었습니다.
What SD card does of take
Will not go past the chrome screen need a SD card what kind
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@bobrien Chromo's use Micro-SD card. Not sure so how this will help your frozen screen. you do want to go ahead and backup all your personal files (pictures, music etc. ) and subsequently try a hard reset to restore it to factory defaults. This will erase all of your files as well as all of your settings. SO, make sure that you have all your email addresses and passwords that you need for a restore. Your tablet is a generic Android tablet, those usually do not have a standard way to Factory Reset. This should work for your Chromo:
Power off the tablet.
Press and hold both volume up and volume down key, while holding, press and hold the power button for a sec to turn it on.
Continue holding both power keys, once powered on the screen will go blank but it will be illuminated with a black screen.
Release volume keys and push volume up or down key to access recovery menu.
You can navigate the menu with vol keys. Use the power button to select the options
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Brenda Obrien 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 16
전체 시간: 361
