주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo IdeaPad 300-17ISK는 2016년 10월에 출시된 17인치 노트북입니다. 모델 번호는 80QH008MUS입니다.
Fan Replacement without heatsink
Hi There, I was wondering if there will be any issues replacing the fan with one of same size but no (what I believe to be) heat sink? Whatever the Copper attachment is. The fan bearing went bad so now it shakes and makes a lot of noise when I use my laptop which is quite annoying, I deal with it by using headphones but can't really take it out because of how loud it is. If I can't replace the fan with aftermarket fans that don't have the copper attachment is there anywhere I can purchase the same fan used for this laptop?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Hi,
Here is a link to the service manual for your IdeaPad.
Scroll to p.55 to view the necessary pre-requisite steps and then the procedure to remove the fan/heatsink assembly.
Scroll to p.87 to view the parts numbers (#12&13) for the fan and heat sink. Search online using the appropriate part number only to find suppliers of the part that suit you.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
this is what you need. https://www.ebay.co.uk/i/192312127707?ch...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Kevin Nguyen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 760
