주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DigiLand DL701Q는 쿼드 코어 1.3GHz MediaTek 프로세서를 탑재한 8GB 태블릿입니다.
Help Set up wizzard
I set up a Google account
Password
I have WiFi network connection
And when I click next is loading and then
It pop up a message saying !!!!!!!setup wizard has stopped!!!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 8
댓글 6개
How do I setup my tablet wizard keeps popping up
의 공유
Hi have yuou been able to set up ur device
의 공유
I'm having the same issue. How do you reset back to the factory settings to be able to start all over again
의 공유
Have you figured anything out having the same problem
의 공유
Trying to set up the wizard on my tablet and it keeps on saying the wizard has shut down I don't know what to do
의 공유
댓글 1개 더보기
댓글 달기
답변 3개
가장 유용한 답변
I had the same problem. To log in dont put any info in at first( no wifi, name, ext) , then when you are in thats when you can fill all of it in
( do allow setup wizard)
이 답변이 도움이 되었나요?
점수 1
댓글 달기
here is the fix to this problem on the Digiland DL-7006 and may work on others as well. follow steps carefully.
http://www.digi-land.net/En/support.asp?...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
First power off the tablet
Second press and hold volume down and power until the digital screen appears
Third as soon as digiland screen appears press volume up, down, and power repeatedly over and over
Fourth use the volume down to select the Chinese symbol third from bottom with Emm in it
Last wait for tablet to power on, it will take a while. When it powers on skip everything. Do not connect to Wi-Fi or set email or tablet pin, SKIP EVERYTHING
tablet should unlock and you can set it up from settings >accounts *add account
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Lily 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 27
전체 시간: 4,444
