주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1세대 Mazda MX-5, 즉 Miata입니다.
Timing belt broke while driving
I have a 1997 Mazda Miata. The timing belt broke and I want to know if there could be any other extensive damage to the engine before I have it repaired. Is there any way of determining other damage?
Thanks;
Pete
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
선택된 해법
From what I've been able to see on line in miata forums these older miatas are non interference designs that won't eat the valves when the belt turns loose. Removing the valve cover and manually turning the cams can confirm this... If any valves show massive clearances at any point of rotation it is of course indicative of bent valve stems. Naturally if you encounter serious resistance trying to turn a cam you should refrain from forcing it.
이 답변이 도움이 되었나요?
점수 4
댓글 달기
@fullcircle15 the Miata engines are non-interference engines. You should not have any piston/valve damage.
이 답변이 도움이 되었나요?
점수 4
댓글 달기
답변을 추가하세요
peter shea 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 34
전체 시간: 3,767
