주요 콘텐츠로 건너뛰기
3 MB 공유 L3 캐시 1.7 듀얼-코어 Intel 프로세서 (Turbo Boost 최대 2.6 GHz).
My MacBook won't turn on
I bought a macbook from someone and I can't seem to get it to turn on. I've tried everything there is, the SMC reset, the NVRAM reset and I also opened it up and unplugged the battery.
There is no chance in getting my money back so is there any other way to do this?
Thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개:
are you getting a green light on the charger
No, there is no light on the LED of the charger
We're having the same problem, but the charger light is green.
댓글 달기
답변 1개
its either an issue with the charger or the logic board, you could try another charger or you will need to take the board out and look around to see if you can see any damage, this might help. https://www.youtube.com/watch?v=v_8yxaEL...
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
It's probably the logic board then. I borrowed the charger from someone else so that definitely works.
Thanks for replying
댓글 달기
답변을 추가하세요
notanexpert 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 145
