주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Xperia Z4(유럽에서는 Sony Xperia Z3+로 알려짐). 1.5GHz 프로세서와 3GB RAM, 2070만 화소 후면 카메라를 탑재한 5.20인치 1080x1920 디스플레이 스마트폰. 2014년에 출시되었습니다.
Display is not working after Dropping
Hi There!!
My phone has been dropped from my hand. Since then the display went completely black. When I tried to turn on, it makes the vibration as normal Sony phones does. But after couple of seconds just the notification LED blinks RED and the motherboard gets overheated. Sent to a local repair shop, but they couldn't fix it. They put a new display , however still does the same. What is the problem and how it could be fixed?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
I could be wrong on this since I'm always learning but it is possible that a component on the board has been damaged. Voltage is sometimes sensitive and with drops, parts could bad. It sounds like a lcd problem since there is no image but if it has been replaced, then possibly the back light or a component for the lcd on the board could be damaged.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
riaj_shuvo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 19
전체 시간: 486
