주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Power Mac G4에는 Mirrored Drive Doors가 있습니다.
CD boot
Will not boot from Apple Install CD or Diskwarrior CD. Optical drive kick CD out when pressing "C" key. Any suggestions?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
Check your drive works, can you boot from hard drive?
댓글 달기
답변 2개
가장 유용한 답변
What install CDs have you been using? The mirror door G4s are a fussy set, will only boot from OSX 10.2.2(approx and above) CDs, not OS9 CDs (even the dual boot models).
If the machine is booting, check the machine can see the CD or DVDs ordinarily, if it isn't the optical drive has probably failed. The last few of those I've looked at I've had to put a new DVD drive in them as the laser had failed.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
향후 수리를 위한 준비
Try holding option down instead, if you manage to boot to the selection, then select the DVD.
What exactly is wrong with your computer that you need to boot from your install disk?
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
pete surckla 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 19
전체 시간: 4,505
