주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 샤오미에서 제조한 7.9인치 디스플레이 탑재 16 GB 안드로이드 태블릿입니다.
What is this component?
Hello everyone.
I'm actually trying to replace my Mi Pad 2 screen + digitizer. When i tryed to unstick the broken screen + digitizer from the frame i made a damages on a component stick to the frame.
This photo is going to show you the front panel empty ( i left the broken screen + digitizer)
이미지
I zommed on top left of this front frame where is the damaged component.
이미지
on the back of the frame at the same place there it his other part of this component
이미지
I'm supposed to plug the mother borad on this :
이미지
Do you think this component is important? It's write on this : "0 w1 mp aac 160328"
Thanks for support =)
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 4개
선택된 해법
Hello mates,
Thanks you so much for react fast like this.
When you said "radio" do you mean FM Radio, same radio that every one can have in his car?
Because the wifi is a radio sgnal (in other frequency).
Will only the FM radio be impacted or all orther radio signals like wifi and bluetooth?
Thanks you again ;)
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
probably all signals, but the damage is so minor that the effects will be negligible. So you have nothing to worry about.
의 공유
WiFi and Bluetooth. Because those two usually use foil antenna under the glass or rear case, while FM radio uses your headphone wire as the antenna. Also I’m bot sure if your device has FM radio to begin with.
의 공유
댓글 달기
가장 유용한 답변
Antenna, you may degrade or destroy radio performance if you damage that part.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Tom chai is correct on what is. As for importance, it should still function perfectly fine with the damage, but as Tom said, it wont be as good as it used to be but it should be perfectly fine for what your using it for.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Thanks for the info,
i was wondering informations before order a new screen kit ( about 50$ ).
Thanks you so much. I still use an old 2012 galaxy s3 4g that run perfectly android 6.0.
Smartphones hardware upgrades is bullshit most part of time.
see you my friends.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Matteo GACHON 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 20
전체 시간: 514
