주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC One 시리즈의 최신 스마트폰으로, 간단히 HTC 10이라고 불리며 2016년에 출시되었습니다.
Adhesive for the screen?
Which one is used in the video?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
Not exactly sure what Eric is using here but I find 3M two sided tape works well in this application
Hope this helps
이 답변이 도움이 되었나요?
점수 3
댓글 달기
I just recently replaced battery and screen(after breaking screen during battery repair). I used double sided tape to hold the screen together. Anything on amazon would probably work, I prefer you get 1mm, 2mm, and 3mm width pack cause the 1-2mm works great for the side bezel while the 2-3mm works good for the top and bottom. Works great except for the lower part where the fingerprint scanner is. I can't get a precise measurement but it seems like the tape is 0.25mm thick, as in the height. This was too thin for the lower part. It would separate and I would see the light bleed out the sides, so I had to double up the tape to get the bottom to stick.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
belokk 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 17
전체 시간: 1,761
