주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년 9월 9일에 발표된 iPad Mini 4는 iPad Air 2의 성능을 더 작은 폼 팩터에 담아냈습니다.
I pad mini 4 screen replacement
Can I just change my glass screen that is cracked on my I pad mini 4; I have taken it to a shop and have been told I have to buy the full casing because you cant just change the glass screen, someone has offered to change just the glass part for me is this possible ?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 2개
선택된 해법
Just to elaborate on Daniel's answer...
The iPad mini 4 has a fused display assembly (LCD is glued to the digitizer), similar to those found on the iPhone and Air2/Pro iPad models. Technically speaking, if only the digitizer is damaged, it can be replaced independently but this requires a repair shop that has a full suite of tools for screen refurbishment. It is certainly not a DIY repair and even an experienced tech will not get good results unless they have the proper tools. AFAIK, very few people refurbish iPad screens.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
I have no trouble replacing just the digitizer and you dont need a "full suite" of tools. Just a tech that knows what their doing.
의
Where i can replace screen
의
댓글 달기
yes you can replace the digitiser
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Where can I get a replacement digitizer for the iPad Mini 4, without buying the whole LCD + Digitizer assembly?
의
you can find them on ebay. tho as minho says its not an easy repair for someone that hasnt done it before as the lcd and digitiser are glued together
의
댓글 달기
답변을 추가하세요
Penny Crossland 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 32
전체 시간: 6,427
