주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Chevrolet Blazer(및 그 사촌 격인 GMC Jimmy)는 Chevrolet K5 Blazer, Chevrolet S-10 Blazer, Chevrolet TrailBlazer, Chevrolet Tahoe, Chevrolet Blazer 등 General Motors에서 생산한 여러 SUV 모델을 지칭할 수 있습니다.
power windows will not work
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 6개
My driver side window will not work. For 4 +years I have been able to use it, but it would work very slow to go up or down when it worked. It's down now, but it will not work at all.
의 공유
How can I get my driver side window to work?
의 공유
@pcoley89 ,
What is the year model of the vehicle?
의 공유
windows don't go up or down and door locks don't work! Checked for power to fuses and there's none ! What could be wrong?
의 공유
@jayeff 1989
의 공유
댓글 1개 더보기
댓글 달기
답변 3개
선택된 해법
If all the windows are not working from any location in the truck then your probably looking at a fuse but if its just one window or from one location ,for example back window works from drivers seat but not from back window door , then your dealing with a switch or wiring issue. If you could be more specific as to what works and what doesn't it could help. Are all windows not working or just one or two?
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
None of the windows go up or down nor the door locks!!!
의 공유
No power to fuses!
의 공유
My issue becomes multiple. When the window switches don't work, the heater meter shuts down ,as well as the cruise control,all at the same time they quit working.??
의 공유
댓글 달기
Check the fuse to see if it is blown. PWR WDOW on panel.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Hi @myersw835
Couldn’t find the wiring diagram for a 1989 Blazer, but here’s an image showing the wiring for the doors locks and windows from a 1988 wiring diagram found here. Hopefully the 1989 wiring is the same as the 1988
It doesn’t show any fuses as such but circuit breakers. It would seem strange that neither would have power to them as the door lock circuit should be powered all the time and the windows would be only when the ignition key was operated i.e. two distinct power feeds.
You may have to trace the wiring back from the two circuit breakers to see if there is a common point.
이미지
(click on image to enlarge for better viewing).
Note: I checked the wiring diagram for the 1991 model and it shows the wiring for a 2-door and 4 door model for the door locks whereas the 1988 wiring diagram is only for a 2-door model and they are the same, but the 1991 diagrams don’t show the power windows wiring
Hopefully this is of some help.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
rcw626 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 35
전체 시간: 8,046
