주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Isuzu Amigo는 3년의 공백기를 거쳐 1998년, 2세대 모델로 재설계된 Rodeo와 함께 미국 시장에 복귀했습니다.
What can I replace the original engine with?
So long story short. My timing belt a couple of years ago broke, resulting in the pistons colliding and damaging the cylinders. I had the pistons re-machined but she failed the state inspection due to weak cylinders. I plan on replacing the piston rings as a first step but was wondering as a last ditch effort can i replace the engine entirely. Therein lies the question. Should i replace it with one of the same make, model, and year. Or can i use a different one entirely.
1998 Isuzu Amigo 150,121 miles
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Daniel Choate if you stick with the same model and year you do not have to worry about potentially having to find brackets mounts etc. to fit the engine. So that would be the easiest. You can most likely use different years for as long as it is the same series. Your 1998 should have the same setup, brackets and mounts right to the 2004 model year and should be a straight forward swap.
You can of course swap some other GM engine into your Isuzu but that get's a bit more involved. It will all depend on your abilities, tools etc.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Daniel Choate 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 27
전체 시간: 1,467
