주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
MacBook Air와 경쟁하기 위해 출시된 2000년대 후반 Dell의 프리미엄 서브노트북 라인업입니다.
damaged internal dc plug
I have a Dell Adamo 13, my internal power connector is broken (the one that is on the motherboard) do you know where i can buy only this part or how to repair it? I don't want to change the motherboard becouse it's only a small piece that is broken.
If this part is unavailable do you have schematics of this part?
Do you have alternative solutions?
Thank you very much
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
I believe that it is soldered to the motherboard. So you do have to take it apart and expose it and see exactly what you need Dell Adamo 분해도 shows you how to get it all apart. I would try to either get it from Dell or one you have the part check on Digikey or Mouser.com
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
in the step 21 of the Dell Adamo Teardown is the one in the upper left with the code 932ca
의 공유
댓글 달기
Replacing the DC jack involves re-soldering on mother board and probably it wont be possible with regular soldering iron. I would suggest to take it to some hardware shop and get it fixed because a wrong attempt can may harm your laptop more otherwise you can try by yourself.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Emanuele 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 9
전체 시간: 2,077
