주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Series II Discovery는 1998년 가을에 처음 출시되었으며, 미국에서는 1999년에 출시되었습니다.
How to replace fuel pressure regulator
No instructions or schematics for 2004 4.6 SE online. They sell the regulator, then say it's in the tank?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
@marshada "All the injectors are fed from a common fuel rail as part of the returnless fuel system. Fuel pressure is maintained at a constant 3.5 bar (52 lbf.in2) by a regulator that is integral with the fuel pump.
이미지
It's in the tank.
Pump - fuel
NOTE: The fuel pump and fuel gauge tank unit are integral parts of the fuel pump housing and cannot be renewed separately
Remove
1. Release fixings and remove battery cover.
2. Disconnect battery earth lead.
3. Models with third row seats: Remove RH third row seat.
4. Remove right hand rear lower quarter trim casing.
5. Models with third row seats: Remove 4 screws securing third row seat latch finishers to body and finishers.
6. Release and remove screw cover from rear floor carpet finisher.
이미지
7. Remove 6 screws securing loadspace carpet finisher, remove finisher.
8. Release carpet and tie aside.
이미지
9. Remove 6 screws securing fuel pump access panel to floor.
10. Remove access panel.
11. Clean fuel pump hose connections.
12. Position absorbent cloth to absorb fuel spillage.
13. Disconnect multiplug and fuel hose from fuel pump housing.
CAUTION: Always fit plugs to open connections to prevent contamination.
14. NAS models: Disconnect pressure sensor pipe from fuel pump housing.
이미지
15. Use LRT-19-009 to remove locking ring from fuel pump housing.
16. Remove fuel pump and discard sealing ring.
Refit
1. Clean fuel pump housing and mating face on fuel tank.
2. Fit new seal to mating face on fuel tank.
3. Fit fuel pump assembly to fuel tank and use LRT-19-009 to fit locking ring.
4. Connect multiplug and fuel hose to fuel pump housing.
5. NAS models: Connect pressure sensor pipe to fuel pump housing.
6. Fit fuel pump access panel and secure with screws.
7. Reposition carpet.
8. Fit carpet finisher and secure with screws.
9. Fit screw cover.
10. Models with third row seats: Fit and secure
third row seat latch finishers.
11. Fit right hand rear lower quarter trim casing.
12. Models with third row seats: Fit RH third row seat.
13. Connect battery earth lead.
14. Fit battery cover and secure with fixings
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
D Marshall 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 14
지난 30일: 49
전체 시간: 5,845
