주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Note 4는 2014년 10월에 출시된 셀룰러 스마트폰입니다. Galaxy Note 4 모델 번호는 SM-N910, SM-N910A, SM-N910T, SM-N910V 또는 미국 버전은 SM-N910R4입니다.
Note 4 No Sign of Life
I've been trying to get this Galaxy Note 4 working, and it is showing no signs of life. When it is plugged in, the notification light does not show. I have tried every combination of buttons I've heard, and it won't do anything. It doesn't vibrate, the notification light does not turn on, and the screen does not turn on.
I tested for voltage on the battery terminals with the battery out and the charger connected, and it shows 4.19 volts.
I have replaced the battery with a known working battery, and it did not act any differently.
I'm pretty certain at this point that it's a hardware issue, but what can I check? Being that I'm getting voltage at the battery, I know the charging port is working properly. The only other thing I can think of is something on the motherboard is bad, but of course if anyone has any idea, I'd love to hear them!
Updated with pictures...
이미지
이미지
I just removed the motherboard for simplicity in the picture.
Tested the battery again... It is showing 3.79V. Still no sign of life. Where is PWR7000? And the other things, for that matter.
Update 2: I removed the cover, everything looks to be alright. The scratch on it is just from a screwdriver... my mistake!
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개
PWR7000 is your power switch
의
I got that, I was just trying to see where the power switch leads in order to check for obvious damage.
Post updated again.
의
댓글 달기
답변 1개
가장 유용한 답변
@boostedmoose115 follow the troubleshooting flowchart
이미지
이미지
If you need to find the components etc. post a couple of images of your motherboard. Use this guide 기존 질문에 이미지 추가하기 for that
Update (01/20/2018)
for U7000 and most of the components you'll have to remove the EMI shield as pointed out
이미지
이 답변이 도움이 되었나요?
점수 2
댓글 6개:
Chances are power management of needs to be replaced.
의
Thank you for posting, I'll double check the battery voltage and go over the rest of the flow chart at some point today and report back.
의
Updated.....
의
Would the V_BAT voltage be the battery voltage? And what is C7128, and how do I check it? I apologize for all the questions, but I can't find anything telling me what these things are. The the wiring diagrams either don't say anything or it's just impossible to see what they say.
의
I personally don't think note 4s are worth repairing for power ic issues. Too easy to crack the screen on open and already tried replacing multiple chips with no success.
Their prone to going bad on this model again anyway.
의
댓글 1개 더보기
댓글 달기
답변을 추가하세요
Alex 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 14
전체 시간: 6,194
