주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung의 주력 휴대폰 Galaxy S8. 2017년 4월 출시.
Broken screen. Can not use touchscreen
I dropped my S8. The part where screen is broken still works. But, the rest of the screen, does not work. Therefore, I can't even turn phone off. And, I can't transfer pictures without touching the allow button. It won't let me. Any suggestions?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 5개
가장 유용한 답변
It's probably a little late, but I used Google voice to do things for me when my phone stopped letting me touch the screen. It allowed me to do many things, if you know the lingo it helps a lot. I just said "ok google (...)" with what I needed to get done on my phone before getting a replacement.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I was able to connect a logitech M557 Bluetooth mouse
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
How did you do that? I want to use it as a dex with a qi charger.
댓글 달기
Laura Rogers the only way to fix this is by replacing the display assembly. Use this guide Samsung Galaxy S8 스크린 교체 for that
이 답변이 도움이 되었나요?
점수 0
댓글 달기
You can definitely replace the Glass and LCD with just the glass and LCD, but for ease of repair, may I suggest buying the glass and LCD with the midframe attached. It has a much better end result in how the repair appears cosmetically.
If you're not feeling that risky, look for your local Ubreakifix. Ubreakifix has a partnership with Samsung with OEM quality parts and prices lower than the part is usually listed online.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I had this put 7Juuu
댓글 달기
Try changing the battery.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Laura Rogers 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 16
전체 시간: 23,189
