주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Xperia Z3는 2014년에 출시된 안드로이드 스마트폰으로, 긴 배터리 사용 시간과 내구성으로 알려져 있습니다.
Changing the digitizer / Lcd
Ok looking at changing the digitizer on the d6603, Question is this: Is the Lcd screen bonded to the digitizer and has anyone got a work around/way of separating the 2? or are the not bonded for sure?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
yes the glass is bonded to the lcd its not expensive for the full lcd so i would replace the whole thing
이 답변이 도움이 되었나요?
점수 2
댓글 6개:
의 공유
That's what I thought though its a fair bit cheaper just to do the digitizer, Any experience of separating one yourself?
의 공유
only with samsung, if you take the whole lcd out you could use lcd cutting wire and a hairdryer or heat gun but you would need a way of holding it down while cutting, i use a vacuum seperator so its alot easier
의 공유
maybe it isnt bonded just watched another video there but it skipped parts. https://www.youtube.com/watch?v=8WhrZnJ4...
의 공유
I do have a reflow machine for other work I do. Lcd cutting wire? Could be subbed for a fine fishing wire? Cheers Daniel will give that a look now, I know the z1 wasn't bonded totally but partially at the bottom from what I remember a few moons back
의 공유
댓글 1개 더보기
댓글 달기
Change the complete lcd. Pretty simple job. If you get the lcd without the frame be sure to adhere properly on the sides. They tend to lift easily and you will be able to see the light through the space on the lcd and frame.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Zerocool278 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 537
