주요 콘텐츠로 건너뛰기
Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
20 질문 전체 보기
My DSI XL can't start any Application
My DSI XL boot normally, but it not able to start any application.
For exemple, it doesn't start wrench icon or camera application on dsi menu.
It not able to start any game.
o got this error:
"an error has occurred. press and hold the power button to turn the system off"
But a can start camera cliking on "L" and "R" buttons.
So, i can't perform factory reset on DSI menu.
How could i reset it phicically?
Tks.
Alexandre Bezerra
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 1개
Observe if you the problems them me. in my case the dsi wasn't able to open any application, include wrech icon.
Try disable wifi wpe2.
do you have any slot card?
댓글 달기
답변 4개
가장 유용한 답변
I had the exact same problem. It was my first attempt at a repair, so I did a ton of work that was not necessary. Long story short, it was a simple fix.
The small wifi sub-board went bad. swapped it with another and all the symptoms went away.
Again, the exact same problem as you - camera works, can't load any application (system settings, insert game, pictochat) or the same error you posted occurs. If that wasn't the problem, I'd be surprised.
이 답변이 도움이 되었나요?
점수 5
댓글 6개:
You need to replace the Wi-Fi module. Good Luck. Next Level, PR
Hi, I have the same problem, but I have no idea what you mean by swapping the small wifi sub-board.
Could you please provide some instructions on the steps we need to follow?
Corey, you are right. I replaced. wifi board and it works.
Tks a lot.
Alexandre Bezerra.
Mine doesn't work and how do you replace the Wi-Fi module. This happened after i updated the system. Can someone explain to me how to replace the Wi-Fi board thingy? thanx
-Razor
Look in these guides for the wifi board guide Nintendo DSi XL
댓글 1개 더보기
댓글 달기
I've replace the wi-fi board still no luck, any other suggestions?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Already replaced wifi module and same happens any advise?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
does this also work for dsi normal
댓글 달기
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Alexandre Bezerra 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 42
전체 시간: 16,442
