주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon의 장망원 콤팩트 카메라 디자인 중 세 번째 버전입니다. 2006년 2월에 처음 출시되었습니다.
LCD screen cracked. Replacement process?
The screen on my camera is cracked.
The screen will not come on at all right now.
I would like to replace it.
I found the blow-up diagrams but is there a correct process?
Do I also need to replace the Back Light Unit?
Thank you in advance for your help!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@nanaburt yes there is and all you have to do follow it in sequence as outlined in this document S3-Disassembly.pdf
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
Thank You oldturkey03. I have the diagrams, Can I start at the point of taking the LCD cover off (after removing the battery) or do I have to remove the screen at the hinge before taking the cover apart?
의 공유
... also ... are there any precautions on where I should NOT touch as I remove the PBC Assembly as I need to re-use the current one if possible.
의 공유
@nanaburt this does look complex but at this point I'd follow the individual steps as they are outlined. Stay away from the flash cpacitor since it does pack a punch. You should always discharge that one before working on a camera. I do try to not touch all over the pcb but there is only a small chance to either shorten things out or cause damage due to static electricity.
의 공유
댓글 달기
답변을 추가하세요
Gale 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 22
전체 시간: 618
