주요 콘텐츠로 건너뛰기
Repair guides and troubleshooting for Presario CQ58 series. These are budget laptops made by Compaq, which was owned by HP from 2002 to 2013.
20 질문 전체 보기
Why my airplane mode button wont turn off
my airplane mode button won't turn off it is orange all the time and i can't access internet. i have tried different ways to connect to wifi using usb tethering, usb wireless port but still i am not able to access internet as the button is stll orange what can i do to turn it off?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 4개
선택된 해법
Go to HPs website and see if there is an updated driver.
There are a few laptops with an airplane mode bug that needs a patch directly from the manufacturer.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
there are two different ways that you can turn off your PC's airplane mode
1: you can disable airplane mode in the notification panel.
2: run the troubleshooter.
3: check the services in the computer manager if it's not running then right your mouse on it then click start.
댓글 달기
Also, check for a keyboard shortcut that enables and disables airplane mode. (Like Fn + F11). Also, you can disable airplane mode in the notifications panel on the right of the screen.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
I have had this issue before, but it was on a del laptop. I ran the troubleshooter, and it fixed the issue. Try going to start and searching troubleshooter, It should bring up a page to run different troubleshooting tests.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
mine isnt working even after troubleshooting. it just states i need to connect ethernet courd in order for my device to work! and i dont own an ethernet, i will not be buying one either.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
sanelisile 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 2,687
