주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Tab E 9.6는 2015년 6월에 발표되었으며 2015년 7월에 출시되었습니다.
No screen output? Any ideas?
Hi
I have no screen output in my friends tab. I do the odd iPhone repair and got stuck with looking at this.
Originally just thought it needed hard reset as there was only a noise when put on charge - nothing else. But didn't work. After various combinations of button pressing (with no screen and no experience of Samsung tabs I was double blind!!) I somehow opened a game - the game music was playing away and again with some screen bashing it could be heard the game firing bullets. I'm told the tab was sat on by a three year old...
Is there a simple screen ribbon cable that commonly comes away etc?
Many thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Hi @bantamdave21 ,
Here is a link to the ifixit Samsung Galaxy Tab E 9.6 Wi-Fi 터치스크린 및 LCD 교체 guide.
It should be of some help to you, as it shows how to open the tablet and dis-assemble it so that youcan inspect the video cable connections etc.
If they seem to be OK perhaps then the LCD screen has been damaged somehow and needs to be replaced.
Search online for suppliers that suit you best.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
가장 유용한 답변
its possible that the lcd ribbon got loose, try reseating it and see what happens
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
That was my thinking just slight worried that the connector is only accessible by removing LCD and glass which from what I've seen looks a good chance of breaking the front glass regardless just didn't know if there was a common thing that was simpler....
의
no you can take the back cover off and the lcd ribbon is beside the battery connector
의
it also depends which end could be loose as the other end of the ribbon goes under plastic and the only way to get to it without removing the lcd is to cut the plastic bit
의
댓글 달기
답변을 추가하세요
David Steele 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 19
전체 시간: 466
