CPU Upgrade from A6 to A10
I have a new A10 with compatible pin config.
But A6 is glued to board -- will glue gun damage board? Other options to remove glue?
좋은 질문입니까?
기기에 대한 안내서, 부품 및 답변에 신속히 접근할 수 있습니다
좋은 질문입니까?
I don't think the CPU is glued to the board.
Rather, I think the CPU is Soldered to the board.
If you are comfortable with soldering, you need to remove the solder from hundreds of pins and make sure the new one aligns perfectly, and that none of the pins are blocked, damaged, or blocked.
Also, the HPs BIOS needs to have information in about the A10 in order for the CPU to work, even if the pins align.
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 5
지난 30일: 11
전체 시간: 189
댓글 2개
It is clearly glue -- it is only on the four corners, it is clearish, and I have been slowly slicing away at it with a razor. No signs of solder yet...
J.J. Lukas 의
Ok, well if its glued on, its a highly resilient epoxy considering CPU temperatures sometimes reach 85 C (185 F).
S W 의
