주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS X44H-BBR4는 2012년에 출시된 인텔 코어 i3 프로세서 탑재 노트북입니다.
Computer won’t turn on
So it started with the power pin being pushed in, I tried to open it up and it didn’t work so I took a break and left it. My dad the genius(sarcasm), decided to do it for me by heating up a knife and making it hot and burning through the plastic around the charge port and pulling it out. He got it, the pin is back but not the computer won’t turn on and like even when I plug in the charger there’s no light it’s purely dead. Any ideas on how to reverse the damage he did?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi,
Here is a video that shows how to open your laptop to gain access to the DC-In jack so that it can be replaced.
You will need soldering skills and tools to effect the removal and replacement of the part.
Here is a link to just one supplier of the part.
It is not a recommendation to use them. It is shown to give an idea of the cost of the part. There are other suppliers online that may suit you better. Just search for Asus X44H Dc-In jack part to get results.
if you find doing this is too daunting, contact a reputable, professional laptop repair service and ask for a quote.
You already know the cost of the replacement part. (send the bill to your father ;-)
Hopefully this is of some help.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
So the problem is most likely stemmed by the dc in jack like it’s not like he scorched something bad or maybe a piece of plastic fell in and like broke something? Because there’s literally a hole into the computer where the dc in port is with like melted plastic surrounding it
의
Hi,
As the DC-In jack is normally soldered onto the motherboard applying heat to it the way it was done may or may not have also affected the motherboard
You won't know the extent of the damage until you open the laptop and inspect the motherboard and everything else immediately around the damaged area
의
댓글 달기
답변을 추가하세요
Saed Daghestani 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 12
전체 시간: 326
