주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony의 40인치 LCD HDTV 시리즈입니다.
SONY LED Screen Lines
I have horizontal lines appearing on my 52 inches LED, Sony Bravia LED , they're on the lower half of the screen, and there is a thick dark dotted line in the middle and below that the image is blurred, how should I fix it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 1개
There are 6 horizontal lines on the screen of Sony bravia and also the the dots at the starting of those lines
의 공유
댓글 달기
답변 1개
가장 유용한 답변
many different things can cause this. have you recently moved the television, or has it been impacted or had liquid on it recently?
1) always start with a settings reset. it doesnt sound like a settings issue, but it doesnt hurt to try.
2) Make sure your source is functioning properly. check a different source, with a different cable, on a different port, and make sure it isnt any of the things listed.
3) crack the device open, and run through the connectors to the LCD. make sure it isnt anything loose.
4) while looking for loose connectors, keep an eye out for blown components, as well as signs of corrosion. repair as necessary.
5) if nothing above fixes the issue, you are looking at one of two things needing to be replaced. The LCD, or the Logic Board. Replace the components one at a time to see which one needs to be done.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Muneeb Hassan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 16
지난 30일: 28
전체 시간: 14,570
