주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
아날로그 TV와 “디지털 지원” TV가 공중파 UHF 및 VHF 디지털 TV 신호를 수신할 수 있게 해주는 저비용 Access HD 컨버터입니다.
Coverter box not working at all
Hi,my name's Myra
I have a dta1030 coverter box,nd my question is,can i reset my coverter box?
Because certain channels blackout,
I cant get channels 29 fox,nd get tv channel 63 is now on 28 nd that doesn't play at all nd neither does all of channels 2 or 35.
Can i get some help?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Hi,
Have you tried just rescanning for all the available channels again?
Are the channels that you mentioned, not being detected at all, or are they being deemed as too low a signal level to be accepted by the converter when it scans for the channels?
Also just checking that the channels are not showing up as 'not viewable' in the converter's Channel List Editing menu
의
댓글 달기
답변 1개
가장 유용한 답변
Move your antenna to a different location, or point it in a different direction. It may be that the missing channels simply don't have a strong enough signal for your box to receive them.
If moving the antenna solves the problem, then you might want to get a better antenna, so that it can pick up all of the channels without having to move the antenna.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
marrah41 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 10
전체 시간: 527
