주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Inspiron 13인치 노트북에 대한 수리 및 문제해결 정보입니다.
Blank Screen - No Boot at all
Hi;
I have 13 inch Dell Inspiron laptop. Today when I tried to power it on it won't boot beyond a blank screen. The screen & keyboard lit up but beyond that it shows no signs of life. There are sounds or vibrations of any sort either, abnormal or the usual ones included.
Can someone please help me?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
The problem seems to have fixed itself.
I tried plugging in the charger earlier & turning the laptop on. But that did not fix it. I shut it down while plugged, turned it on after 15 minutes & it worked.
댓글 달기
답변 2개
가장 유용한 답변
@outflanker could be an issue with the hard drive and your computer not finding it. Try to go into your BIOS on startup. See if that shows your HDD. To get into your BIOS try pressing the "F2" key on the laptop keyboard as soon as the laptop starts up.
If you cannot do anything I would suggest you remove the HDD the battery the memory and the AC adapter. Then hold down the power button for about 30 sec. AFter that plug the AC adapter in and try to start your computer listen for any POST beeps. If it does turn it off and replace the RAM module one stuck at the time. Try to start it again. Let us know what you find. Oh, you also want to give us the exact model number There are a lot of Inspiron models...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I'm having the same problem. It's a Dell Inspiron 15
7000 Series - 7537
Reg Model: P36F
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Outflanker 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 4,473
