주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus ROG Strix GL702VM-BHI7N09는 2017년 1월 Asus에서 출시한 게이밍 컴퓨터입니다.
Replace broken internal speakers?
I bought new parts for the internal speakers, but I'm not sure how to install them. I have updated the audio drivers several times previously but to no avail. My guess is an acquaintance of mine accidentally blown the speakers resulting the problem.
Update (04/01/2018)
The audio worked fine when I was using my earphones.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi,
Is the audio OK when using headphones?
If not then perhaps the speakers are not the problem and you may have a problem with the audio controller.
As it is most probably mounted on the motherboard, the simple way to get around the problem would be to use a USB sound card.
Update (04/01/2018)
Hi,
Just covering all bases. ;-)
Cannot find a speaker replacement guide for your laptop but here is a link to the ifixit Asus ROG Strix GL702VM-BHI7N09 하드 드라이브 교체 guide, which should get you access to the motherboard. Hopefully it will be easy to see how to replace the speakers once you have got that far.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Faiz Zailani 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 19
전체 시간: 1,100
