주요 콘텐츠로 건너뛰기
This instant camera from Fujifilm now boasts a slimmer and lighter body than previous revisions. The Mini 8 helps the photographer by alerting them the recommended aperture. It also has a High-Key flash mode which helps the photographer attain soft portraits for a stunning look.
355 질문 전체 보기
camara has cristal white dust in ot and doesn't turn on
I had my polaroid in a box during months because I couldn't afford the paper. Now I bought the paper but when I open the box, the camara has cristal white dust in ot and doesn't turn on. When I check the batteries one of them has more of this white cristal like dust and they both look like. they are cover in oxid. I think one of them explode, and now I don'tknowwhat to do, or if the camera could kepp working. I'm sorry if my problem seemssilly but I dont know anything about cameras or batteries
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 4개
가장 유용한 답변
@andreavic it will be helpful if you can post some pictures with your question of where exactly the damage is. Use this guide 기존 질문에 이미지 추가하기 for that so we can see what you see.
Your alkaline battery is most likely leaking and it is absolutely possible that one of your batteries has ruptured. You need to remove the batteries. Then clean everything with a fine brush first (wear some eye protection against any flying particles) and after that use a cotton tip applicator and some vinegar to clean the corrosion off. Then evaluate all the contacts to make sure they are still complete etc.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Thank you for your help
@andreavic not to bad. Brush off the loose stuff first than use some vinegar to clean the rest. Clean off the vinegar with some isopropyl alcohol .
댓글 달기
이 답변은 원래 다른 질문의 답변입니다.
@andreavic check your same question on here camara has cristal white dust in ot and doesn't turn on
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
It does sound like the battery leaked out. Pick off the thick particles with a toothpick. Dab a papertowel/cloth with vinegar and scrub the remaining corrosion. Check the contacts where the battery is held and use the cloth/papertowel/cotton swab to clean it off. White down to ensure no more liquid exists.
Test new batteries. Hope this helps.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Hi @andreavic ,
Check the battery manufacturer's website regarding their policy on leaking batteries.
Some large reputable battery manufacturers state that they will replace electronic equipment damaged by leaking batteries (subject to them being satisfied that it wasn't caused by user misuse etc.)
It's worth checking out.
If it is applicable in your case, make sure that you keep the faulty batteries and take pictures of the damage caused etc. to assist in your claim
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Andrea 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 7
7일 전: 14
30일 전: 47
전체 시간: 1,215
